25% OFF on Orders $500+
- Support aptx HD, aptX AD, aptX, aptX LL and able to stream and receive HD music.
- Transmit all source and enjoy on your headphone.
- HDMI ARC, Phono in, RCA in, optical in, sub out and more connectors fit your home stereo system.
- Bluetooth transmitter and receiver Meet All Your Needs: Home AV, Bookshelf speaker, PC, Gaming and Hotel/Home Background music.
- 50W x 2 powerful Bluetooth amplifier for your passive speakers, bookshelf speakers and mobile devices.
- Free iOS & Android GO Control App and Remote Controller
- Tune your own sound with our tool - ACPWorkbench
- the best bluetooth amplifier for wired speakers
Elevate Your Audio Experience
Easily stream from your smart phone, tablet, laptop, or TV to your passive speakers with B50 Bluetooth transmitter and enjoy HD audio.
An Bluetooth Amp Could Meet All Your Needs
B50 Bluetooth transmitter and receiver is the perfect addition to any audio system, with compatibility for TVs, vinyl players,aa AV receivers, projectors, subwoofers, USB sticks and more.
Bring Powerful Sound To Your Home
Transform the way you listen to music at home with the B50 Bluetooth Stereo Amplifier.
With 50 watts of power per channel, the B50 bluetooth transmitter is designed to provide high-quality audio to a pair of passive speakers, delivering immersive sound to your living room, kitchen, workshop, bathroom, or any other space.
Bluetooth Transmitter Mode
Transmit All Source & Enjoy On Your Headphone.
With B50 Bluetooth transmitter, you can wirelessly connect to your Bluetooth headphones or speakers and enjoy your music, movies, and more.
Share The Sound With B50
Dual Link For More Fun
With B50 Bluetooth transmitter, you can easily share your music with 2 Bluetooth devices at once.
Its dual link technology allows you to transmit to two devices at the same time via aptX HD, so you can enjoy the brilliant sound with your family, friends, or loved ones.
Stable & Long Distance Connection
Experience uninterrupted, high-quality audio in your home. B50 ensures that you can enjoy smooth, seamless music all day without any choppiness or cut-offs. Upgrade your listening experience with B50 Bluetooth amplifier today!
The B50 Bluetooth amplifier adopts an aluminum alloy enclosure design, a finely processed sandblasting technique.It ensures good heat dissipation, corrosion resistance, strong hardness, and no deformation, prolonging the usage life of B50 bluetooth transmitter and receiver.
Free iOS & Android GO CONTROL App
APP Control
With user friendly playback control, EQ control, Input mode switching and simple Bluetooth connection setup. The APP is free for B50 Bluetooth amplifier.
ACPWorkbench
Tune Your Own Sound
4.6.45.2, 15m
24V 4ohm 50W *2
24V 8ohm 30w *2
4 - 8 ohm
20Hz to 20Khz
Line Out x 1 / 1 Vrms(3.5mm mini jack)<0.1% @ 1W 1kHz
>93db
Analog RCA, Max 2V RMS input
Analog RCA, support MM/MC
Max 192kHz/24bit sample rate decode
PCM encoding
PCM only
Sample rate: 48kHz
Support codec: mp3(data rate up to 384kbps), mp4, wma, mov, m4a, aac, flac(96kHz/24bit), ape
Max 3V RMS output, Frequency Response: 250Hz
50W per channel @ 4ohms
24V/4.16A
185 x 155 x 50mm
900g
50W x 2
50W x 2
Phono in
Sub out
Sub out
USB Type - C
Micro USB in
48khz/16bits
44.1khz/16bits
GO CONTROL
4STREAM
Does B50 Support CEC control?
How far is the Bluetooth amplifier receive and transmit distance?
Both receive and transit distance is about 15m. When transmit to 2 Bluetooth devices at the same time, it is 10m from B50 Bluetooth transmitter to other Bluetooth devices.
How is the Bluetooth transmitter and receiver delay?
Yes for sure. For iTunes you can use Airplay with our S50 Pro+ wireless preamplifier.It is about 30ms, very hard to notice the difference with human ears. There is about 3-4s delay when connected to 2 Bluetooth devices.
What is the aptX HD chip inside B50 Bluetooth transmitter?
It is Quadcomm QCC3040
How do I connect my phone to B50 Bluetooth amplifier?
Just a few steps
1. Turn on B50 Bluetooth amplifier.
2. The Bluetooth LED indicater will be flashing which indicates it is waiting for connection.
3. Open the Bluetooth connection settings on your iPhone or Android phone.
4. Choose B50 Bluetooth amplifier device to connect with.
5. The Bluetooth LED indicater will be solid which indicates the Bluetooth is connected.
What does B50 Bluetooth amplifier do?
B50 is a Bluetooth amplifier that can be used to increase the audio signal sent or received by any Bluetooth device. What's more, it can be used as a Bluetooth transmitter. Deliver the audio signal from your TV, Vinyl, CD player, or more home audio devices to Bluetooth earbuds, Bluetooth headphone or Bluetooth speaker.
Should you have a B50 Bluetooth amp?
B50 is a functional Bluetooth amp with rich interfaces that can boost your sound system and integrated multirple audio sources in one system. B50 also can be a Bluetooth transmitter which can transmit audio to your Bluetooth earbuds, Bluetooth headphones or Bluetooth speaker wirelessly. So if you are looking for a Bluetooth amp to upgrade your whole house audio system, B50 is a perfect choice for you.
What is a Bluetooth transmitter and receiver?
A Bluetooth transmitter is a device that allows you to stream high-quality audio from your phone or tablet to speakers or headphones. It emits a signal that you can control with your mobile device. Conversely, Bluetooth receivers can be connected to either analog or digital stereo systems, enabling you to listen to music from your phone through the speakers.
Usually, Bluetooth transmitter and receiver won't design together as a device. But B50 Bluetooth Amplifier does.
How do I connect my B50 Bluetooth transmitter?
When your want to use B50 as a Bluetooth transmitter, you need to follow the easy steps below:
1. First, once you are in one of the source input modes (Line in / Phono in /
Optical in / HDMI ARC / USB disk drive / USB DAC) press the reset button on the back or press the Bluetooth transmitter(BT TX) button on the remote controller to enable.
2. Once enabled, you will notice the Bluetooth LED will start flashing, the device will then search for nearby Bluetooth receiver device (Bluetooth Speakers, headphones) and connect to it.
3. Once connected, the Bluetooth LED will turn to solid.Then you are done.
*Some Bluetooth receiver device might need you to enter pairing mode first, some Bluetooth receiver device might need to press a connection button to establish the connection. Please refer to the device user manual or contact the seller for advice if needed.
What is a Bluetooth stereo?
A Bluetooth stereo is a type of audio system that uses Bluetooth technology to wirelessly stream music from a compatible device, such as a smartphone or tablet. It typically consists of two or more speakers that are paired together via Bluetooth to create a stereo sound experience.
For B50 Stereo amplifier, you can use it to power your bookshelf speaker or passive speaker to build advanced Bluetooth stereo system. B50 support ACPWorkbench tuning tool which allows you to tune different audio on each channel. So you can enjoy you customizable Bluetooth stereo with B50 Bluetooth stereo amplifier.
It has received 107 reviews.
